ORIGINAL: vatechguy3
bump...
got a pipe a header for this engine yet?
tony
I just got this for the DLE 35RA:
http://www.troybuiltmodels.com/items...HEADER-25.html
Got it from Troybuilt...$35.00...not bad.
It' made for a ZDZ40 Rear Exhaust and they have a straight, as well as the 25mm drop down header.
I was fully expecting to have to mill an adapter plate but it turns out that the mounting hole alignment is perfect...don't have to do anything to mount it up. May open the pipe flange a bit to more closely match that of the motor exaust port as it looks a bit restrictive.
Going to put it and a ES Composites 40cc pipe in an old Piedmont Focus II that currently has a YS140DZ in it. Need to lengthen the pipe tunnel a bit. Weight & performance should be interesting.
