RE: How to Correct Measured Thrust for Density Altitude?
Actually on the above formula, you don't need to measure velocity manually, if you have Thrust data you can get information about the velocity. The only difference is the mass flow rate but you can assume they have constant flow rate or you may consider fuel flow rate if you would like.
