RCU Forums - View Single Post - Saito 112 90 degree Vee Twin
Old 09-16-2012 | 05:20 PM
SrTelemaster150's Avatar
SrTelemaster150
Default RE: Saito 112 90 degree Vee Twin
ORIGINAL: Hobbsy
That 90 degrees is there whether or not I wrote it down. This from Kevin Cameron of Cycle World, the reason for the famous Harley lope at idle was that when the rear cylinder was on its intake stroke the air fuel mix turned 90 degrees left after leaving the carb, as the front cylinder began its intake the air fuel mix had to stop abruptly then change directions to the right. The cams could be arranged to make one fire like yours but that was not normal.
http://www.wildwestcycle.com/f_firing.html
http://www.freerepublic.com/focus/f-chat/1464309/posts
In this link they do reference the XR-750 as a "V Twingle" having a firing sequence of 45*-675*, but the Harley Davidson street "V" Twins" are 315*-405*
http://en.wikipedia.org/wiki/Big-bang_firing_order
BTW: I was never aware that the XR750 ("V Twingle") had a different firing sequence that the Harley Davidson "V Twin".
