RE: NEW KMP 95
Has anyone had any issues with the wing center section and nacelles on this plane besides the "Doopy Tip" problem.
I am pretty far along in my build and set the plane on the gear with the engines monuted and noticed a huge amount of right thrust in the right nacelle and none in the left.
Although the left had no right thrust, it was pointing hard down instead. I checked to make sure it wasn't the mounts or anything else.
Turns out it is the firewalls on the nacelles that aren't right.
I am assuming it should have some right thrust on both nacelles, but for one to have no right and lots of down thrust instead seem odd.
