RE: NEW KMP 95
Eldher, that is what I would have expected. Some down and a little right. The right nacelle would never square up completely with the wing center section. There is a 1/4 inch drop at the back where they meet.
I had to do some serious sanding to get it that close. I had to twist the nacelle and clamp it while the epoxy cured. You could hear wood crack as I clamped it. The pockets for the spars weren't the same in the center and the nacelle. The one in the wing center section was skewed and the spar wouldn't fit in it until I sanded the corners of the spar off.
I have emailed ARFpros where I purchased from to see it I could get replacements.
I'm at work right now, but when I get home I'll throw some pics up.
