RE: CDI gr8flyer55
Hi Jake
<span lang="en" id="result_box"><span class="hps">In the</span> <span class="hps">code</span><span>, you can also</span> <span class="hps">wait</span> <span class="hps">for the Hall</span> <span class="hps atn">input (</span><span>GP2</span><span>)</span> <span class="hps">signal</span>
<span class="hps">when there</span> <span class="hps">is</span> <span class="hps alt-edited">ignition timing</span> <span class="hps">delay</span> <span class="hps">is not ready</span><span>?(<span lang="en" class="short_text" id="result_box"><span class="hps">Look at the picture</span><span>.)</span></span></span></span><span lang="en" id="result_box">
<span class="hps">It's okay</span><span>?</span>
<span class="hps">Not</span> <span class="hps">Cultivate</span> <span class="hps">the consequences</span><span>?</span>
<span class="hps atn">Spark-</span><span>ignition</span> <span class="hps">failure</span><span>?</span></span>
<span lang="en" id="result_box" class="short_text"><span class="hps">Solution:</span></span>
<span lang="en" id="result_box"><span class="hps">Disable</span> <span class="hps">external</span> <span class="hps">interrupt</span> <span class="hps">input</span><span>, ignition</span> timing <span class="hps">delay</span> <span class="hps">time?</span></span>
<span lang="en" id="result_box" class="short_text"><span class="hps">What do you think</span> <span class="hps">about this?</span></span>
