RE: prop ballancing 24 10
For wood props, instead of sanding on the heavy blade to lighten it, what is wrong with just spaying some urethane on the lighter blade? Seems to work fine for balancing and you do not mess up the prop's finish. Of course, ifone buys props that are not close to start with, then this does not work until you get the prop close.
