RE: BJCraft Episode
Steve,
You will be very happy with the Pletty. Very quiet even hard mounted. A Pletty is in the nose of the Nuance I won the NATS with. Great power, very similar top end to the Neu, but the bottom is much softer. You will want to run a fairly aggressive throttle curve to get the bottom end you want, but once you get it, you will be very happy. No maintenance. Just go to the field and fly.
Arch
