RE: TOP FLITE GIANT SCALE P51 ARC
Thank you.
I plan to finish the plane with the following scheme. The wing will be painted with silver, as for the fuselage I probably will use some aluminum tape.
Aluminum finish require a very smooth area without any imperfections, to do so I will apply about 6 coats of primer with a variation of fine sanding between.
