RCU Forums - View Single Post - transmitter reliability concern
Old 09-19-2012 | 06:43 PM
aeajr's Avatar
aeajr
Default RE: transmitter reliability concern
Are the ailerons on a Y cable or do you plug each into its own slot.
Do you disconnect the aileons at the end of the day or do you leave them connected.
If you disconnect them then it is likely when you reconnected them you reversed them.
