RE: Story of Two StuG's
I would like to see your NoTek light for the StuG42. Here are the photos of my progress on the StuG III G based on the M chassis...
I cut the battery box out of the lower hull and re-installed the gear boxes. I will replace the plastic stock TU's with 3:1 metal when I get the chance.
Plugged the switch holes on the left side of the lower hull and the the bottom as well. Also closed and filled in the gaps on the battery box cover.
Replaced the chain on the tow hook with a more scale chain and made it so it could be removed. Need to make the clips that hold the pintel in place.
Added weld detail to the fighting compartment of the upper hull and textured the armor plate.
