ORIGINAL: shannah
ORIGINAL: vquick
Does the episode canopy fits the nuance
Yes and No
The Episode canopy and Nuance canopy have the same overall shape but the Episode canopy is attached with the quick release buttons.
I assume you are asking in order to determine if you can add an Episode canopy and 'channelizer' to a Nuance. There are changes in the Episode for the channelizer. According to BJ, the stab position and incidence are changed in order to work with it. Rudder is different. Wing is different.
I checked my notes and BJ says that the height of the wing is also different between the Nuance and Episode, so even if you modified stab position and incidence it is possible you would still have some coupling and issues with axial rolls. So, it would be a pretty substantial modification to try and turn a Nuance into an Episode.
