RCU Forums - View Single Post - engine rough when plane inverted
Old 09-21-2012 | 01:02 AM
NM2K
My Feedback: (14)
Default RE: engine rough when plane inverted
ORIGINAL: berge
I have a os155 pumped motor in my large scale space walker. when i do some maneuvers where i roll the plane inverted the engine blows smoke and falters . If I do same maneuver later in flight when tank is about 1/3 full . the engine runs good ? i thought with a pumped engine there would not be a problem like this ! The tank is in normal position behind bulkhead and the center sits just above carby {the motor is inverted} Any clues Help would certainly be appreciated Thank You
Most pump/regulator devices will lose regulation if exhaust pressure is applied to the fuel tank vent. Disconnect muffler pressure, if it is being utilized, and see what happens.
Ed Cregger
