RE: Koverall creases?
If you tighten it enough before you apply the Nitrate you wont have any problems with the creases. If you are applying on a Solid surface and NOT using a tightening dope you may have to apply some heat to the creased area after tightening but before adding the finishing resin or urethane (which ever you will be using instead of Nitrate)
