ORIGINAL: llkoolskillet
Are you boreing the sleeve larger and then finding a piston to fit?
more or less....except i am only honing the sleeve.... and I will find a piston of that style and I can either take the piston down to fit the sleeve, or take the sleeve down to fit the piston... I will likely use a piston from a P5 XLT...tho i will check my engine box and see if there is anything else suitable....
