RCU Forums - View Single Post - CDI gr8flyer55
Old 09-21-2012 | 09:42 PM
  #353
nyemi
Default RE: CDI gr8flyer55
<span lang="en" id="result_box"><span class="hps">Hi</span> <span class="hps">Jake</span>
<span class="hps">My</span> <span class="hps">suggestion.</span> Not u<span class="hps">nused</span> <span class="hps">pins.</span> <span class="hps">You are</span> <span class="hps">created</span> <span class="hps">to</span> <span class="hps">output.</span> <span class="hps atn">(</span><span>Gp4</span><span class="atn">-</span><span>GP5</span><span>)</span><span>.</span>
<span class="hps">The</span> <span class="hps">GP3</span> <span class="hps">Connect</span> <span class="hps">GND</span><span>.</span> <span class="hps atn">(</span><span>CONFIGURATION</span><span>:</span> <span class="hps">MCLR</span> <span class="hps">=</span> <span class="hps">OFF)
</span></span><span lang="en" id="result_box"><span class="hps"><span lang="en" id="result_box"><span class="hps">Multi</span><span class="atn">-</span><span>spark</span> <span class="hps">optimum.</span>
<span class="hps">Minimum</span> <span class="hps">spark</span> <span class="hps">energy =</span> <span class="hps">20 mJ</span>
<span class="hps">1W</span> <span class="hps">=</span> <span class="hps">1J</span> <span class="hps">/ s</span>
<span class="hps">10W</span> <span class="hps">power</span> <span class="hps">inverter</span><span>.</span> <span class="hps">(6V</span> <span class="hps">*</span> <span class="hps">1.7A</span> <span class="hps">= 10.2</span> <span class="hps">watts</span><span>)</span>
<span class="hps">Energy is</span> <span class="hps">10J</span> <span class="hps">per second</span> <span class="hps atn">(</span><span>1000ms</span><span>)</span><span>.</span>
<span class="hps">10J/1000mS</span> <span class="hps">= 0.01</span><span class="hps">J</span> <span class="hps">=</span> 1<span class="hps">0mJ</span> <span class="hps">*</span> <span class="hps">2ms</span><span>!=20mJ
</span></span></span><span class="hps">
</span></span><span lang="en" id="result_box" class="short_text"><span class="hps">Consequences</span><span>:</span> <span class="hps">10W</span> <span class="hps">inverter</span> -<span class="hps">20mJ</span> <span class="hps">sparks</span></span>=<span lang="en" id="result_box" class="short_text"><span class="hps">2ms!</span> <span class="hps">
</span></span><span lang="en" id="result_box"><span class="hps">Capacitor</span> <span class="hps">charging.</span>
<span class="hps">The charging time is</span> <span class="hps">another</span> <span class="hps">approach.
5T(Tau)=2mS=99,3%=~19,86mJ <span lang="en" id="result_box"><span class="hps"><span lang="en" id="result_box"><span class="hps">spark</span> <span class="hps">energy </span></span></span></span></span></span>
<span lang="en" id="result_box"><span class="hps">4</span></span><span lang="en" id="result_box"><span class="hps"><span lang="en" id="result_box"><span class="hps">T(Tau)</span></span>=1,6mS=98%=~19,6mJ <span lang="en" id="result_box"><span class="hps"><span lang="en" id="result_box"><span class="hps">spark</span> <span class="hps">energy </span></span></span></span></span></span><span lang="en" id="result_box"><span class="hps">
3</span></span><span lang="en" id="result_box"><span class="hps"><span lang="en" id="result_box"><span class="hps">T(Tau)</span></span>=1,2mS=95%=~19mJ <span lang="en" id="result_box"><span class="hps"><span lang="en" id="result_box"><span class="hps">spark</span> <span class="hps">energy </span></span></span></span></span></span>
<span lang="en" id="result_box"><span class="hps">2</span></span><span lang="en" id="result_box"><span class="hps"><span lang="en" id="result_box"><span class="hps">T(Tau)</span></span>=0,8mS=86%=~17,2mJ <span lang="en" id="result_box"><span class="hps"><span lang="en" id="result_box"><span class="hps">spark</span> <span class="hps">energy </span></span></span></span></span></span><span lang="en" id="result_box"><span class="hps">
1</span></span><span lang="en" id="result_box"><span class="hps"><span lang="en" id="result_box"><span class="hps">T(Tau)</span></span>=0,4mS</span></span>=63%=~12,6mJ <span lang="en" id="result_box"><span class="hps"><span lang="en" id="result_box"><span class="hps">spark</span> <span class="hps">energy
</span></span></span></span><span lang="en" id="result_box" class="short_text"><span class="hps"><span lang="en" id="result_box" class="short_text"><span class="hps">I</span> <span class="hps">hope so.</span> <span class="hps">I know</span><span>.</span></span></span></span><span lang="en" id="result_box" class="short_text"> </span>
