RCU Forums - View Single Post - Another NitroPlanes Conversion (CMP T-45)
Old 09-22-2012 | 02:24 AM
Xairflyer's Avatar
Xairflyer
Default RE: Another NitroPlanes Conversion (CMP T-45)
Looks good tony
Your Wing loading is going to be a bit higher now (not what you want with a hawk) so make sure you have no droop on the ailerons, a little above centre even preferred, all the washout you can get will help prevent any tip stall when making that last turn.
