RCU Forums - View Single Post - CDI gr8flyer55
Old 09-22-2012 | 01:03 PM
  #368
gr8flyer55
Default RE: CDI gr8flyer55
Jake, got the two edits done and it worked. Now the next problem. As I start the engine everything works good. Advancing the throttle slowly is good, till I reach full throttle, then I can hear the ignition cycling on and off like an rpm limiter and the engine just acts like it needs more advance. My curve is set for 28 * at 6000 rpm till 8000 rpm, then it starts it's decline in degrees of advance. I have this same curve in the first test version and it worked just fine. Do you think I need to go past 28 to maybe 30 or more? Seems like something is really holding it back from revving up like I mentioned, an rpm limiter?
Didn't see anything in the source code mentioning it or where it would cut off the ignition and cycle it back on. See what you can find out about this new quirk.
John
