RE: CDI gr8flyer55
Hi Rob, just tried your suggestion. This a 2 stroke engine. If I change the degrees to 10 or 15 the engine quits at that point, it has to be 28 degrees, working fine now. I will post my curves after the next engine run test. Everything else in the settings was redone and now is working good, getting good top rpms at 28 degrees at 6000 rpm to 7500, no misfires, just runs like a dream.
I tried the 2 edits in the lines Jake suggested and that worked to switch the sensor problem. The rest was a set-point in startup settings. Curves now are all even with or below the redline for given rpm in the graph.
John
