RE: Biplane aileron setup
Easiest yes, but it doesn't let you set up aileron differential other than doing it mechanically. It also doesn't let you use subtrim and end points to get all for throws exactly right. Sure, using separate channels means plugging in 4 things instead of two, but the flying characteristics you'll get from a perfectly trimmed plane are worth it.
