RE: COMP-ARF A-4 BUILD
David,
Your findings and the problems we too have had along with others concern me greatly. I to have the kit and am trying to build this jet for the JWM -2013. We NEED ANSWERS COMP ARF on how to fix this issue!!!!!!!!!
On another note, I found that the gear that I have doesn't even fit the wing properly in the older kit that I bought. I bought one of the original kits and it did not come with the gear. I had to order the gear and Low and behold, they redesigned the main gear and shortened it causing all kinds of creative modifications to get them to fit properly. Moreover, they changed the suspension to an air system that is prone to leaks and isn't even remotely scale. I have found a set of springs that does the same thing and am hopeful that they will work.
I never thought that after spending so much money on a kit that it would be fraught with so many problems and issues.
Andy
