ORIGINAL: karolh
I plan on taking an old model out of storage and putting it back into service. It has one servo per aileron but uses just the lead from ch.1 which is split to power both servos, and this system has worked without a problem. Is there any significant advantage in having a dedicated ch for each servo e.g. ( Flaperon) over the present arrangement.
Karol
Back when we had to use a Y Harness for such a setup, there were numerous instances where I encountered servo anomalies that were resolved by replacing the Y with a new one or one with 20-22ga wire. I stopped using them when JR introduced the Matchbox. I now use Channel Mixing where ever possible. Avoid using Y Harnesses and especially Reversing Y Harnesses such as for Dual Elevators or Dual Flaps.
