RE: Comp ARF Spitfire build
If it helps I found the same on mine and mounted the engine so spinner matched the cowl but adjusting at the firewall with some shims.
I had no problems and flew great with only minor trim change and tracked well on take off. If I remember offset is required as per manual and this is built into the firewall and cowl but some adjustment will probably be needed in most cases
