ORIGINAL: SeamusG
Make sure that you fuel proof the inside of the fuse in the tank area - bottom, sides and top. Use the same material used for the firewall. Much easier to do if the fuse hasn't been closed up or there is a tank hatch.
Yep, I'm right in that area of my build. I was thinking I probably should start researching a technique.
<br type="_moz" />
