If you guys get a minute could you look at my Kadet MK II instructions and see what you think of the fuel tank placement? I'm right at the part where I glue the firewall onto the fuse.. I'd appreciate some opinions on this part. So far I haven't drilled the big 1" hole, just two smaller diameter holes , one at 6 o'clock for the feed line and on about 10 o'clock for the vent tube..
edit.. Reason I ask is from what EddieC just posted.. The plans tell me to wedge wood right against the tank.
<a href="http://www.kavanrc.de/instructions/sigrc49kadetmkii.pdf" target="_blank">
</a>
edit again... well I guess it does tell me that the blocks can be borken out and not to put them to tight against the tank?<br type="_moz" />
