ORIGINAL: jetnuno
Hi
Does it matters where you string it in the for and rear position? Also I guess the lenght of the cable should be the same in both parts, right?
The plane is beatifull. Is it a Airworld F5?
Regards
Nuno
it wont matter where its strung up, when level it will always hang directly under its CG .. with its weight wanting to find center, this will end up always directly under the pulley. The plumb bob is just a pointed that's always paralel with gravity
~V~
