RCU Forums - View Single Post - Monsoon XTR
Thread: Monsoon XTR
Old 09-25-2012 | 11:33 AM
Dads like rc too
Default RE: Monsoon XTR
ORIGINAL: kelynsdad1023
how far out did you bring the LSN ?? Till its flush with the carb body and then tune from there ? I'm guessing that may be the problem too the local hobby shop guy said the same thing. Also would the exhaust gaskets from a .21 engine work on the . 28 ?
I'm not sure about the gasket. I've only had the SH .18 and .28 engines. As far as the LSN, as you've probably noticed, its hard to tell where flush is. I just backed it out until it was obviously too far. I figured worst case scenario was to get it started and find it bogging down from too much LSN. That's exactly what happened. I turned it in about half a turn where it at least wanted to try and run but was still very heavy. Then I just fine tuned from there. Funny thing is, I have no problem with the needles, but I never thought my LSN being too lean would make it run hot. I guess the HSN was compensating for the LSN. You learn something evertime you play with these things.
