RE: DLE-30 idle
The idle issue will improve as the engine breaks in . After it breaks in you will be able to retune for a lower more reliable idle . Untill it breaks in you will need to run a slightly richer low needle to get idle consistency, unfortunately this will add to the mid range burble . A little burble is better than an unreliable idle speed IMHO.
