ORIGINAL: furloughed ual
Hey guys, I have the newest version of the 180 RX. As far as I know, it's the only one out there right now. It is the latest verions with all the above mentioned mods done. It's got the new combustion chamber, a shaft tunnel mod, oil system mod, and new turbine wheel. This is the version that will be availabe soon as the production 180RX.
I have 4 hrs run (29 runs or so) time on it now. Bob sent it to me and told me to ''torture it''. I've been really pleased with it. It has very good acceleration and hasn't missd a beat. Very smooth and consistent starts each and every time. I am able to set both the throttle response for IDLE RPM to ''FAST'' and the HIGH RPM to ''FAST'' and slam the throttle stick from a stabilized idle and get very smooth transitions to max RPM. This was done at 8000' density altitude without issue, so it will be superb for you ''flat landers''. No matter what I do to the throttle, I can't get it to hiccup. As I mentioned, acceleration is very good even up here in CO. The best part is that is has a really nice ''feel'' to it in flight. Nice response and feel when making throttle changes at low RPM on final.
A very nice turbine. The wait was worth it.
Hi,
Please can you explain what you mean by "the only one out there", "latest version with all the mods" etc etc. When did you get your 180 and when was it produced by Jetcat? As an owner of 4 180s I'm keen to find out exactly what engine you have compared to mine.
There have been 180RXs out since the beginning of the year. I have spoken to Jetcat Germany about your post (to see if mine were due updates) but they are not aware of 'new versions' or 'latest mods'. There was a minor manufacturing issue which led to some 180RXs needing some remedial work but that was a just a casting issue - not an engine redesign.
Look forward to the gen.
Rgds,
Mark
