ORIGINAL: BarracudaHockey
No regulators, fast charging, no self discharge. Really no downside.
Re: Regulators
I learned how problematic regulators can be the hard way.
I put an 8A regulator on my plane to power eight high torque servos and one regular servo.
Everything was fine until I hit the forth or fifth servo connection.
When turning on the plane the servos would freeze or start moving erratically.
Or if everything came up correctly, moving more than a certain number of servos at the same time caused the same behavior... ( no there is absolutely NO binding anywhere... )
It turns out that each servo throws a momentary spike as it powers up and of course while it is in motion. This puts a very fast transient on the line that overtaxes the regulator, exceeding it's capacity for a fraction of a second.
I ended up with two 8A regulators on the plane to eliminate this problem.
Each regulator had IMHO fairly small CAPs, so I assume that's the main reason for the problem.
NiCD's and NiMH batteries suffer no such issues as they can tolerate the momentary high draw with aplomb.
