RE: Ailerons not straight
A picture from directly behind the model would give the most info. Right on the centerline is best, showing both wings equally. Move the camera up and down until you see as much wing above the TE as below it. Move side to side until you see the same amount of fuselage to the right of the rudder TE as to the left. The camera winds up in the same place your eyeball would be if you were looking for wing warps.
