RCU Forums - View Single Post - Rudder pull-pull Setup Problem
Old 09-09-2003 | 06:37 PM
ml3456
Default RE: Rudder pull-pull Setup Problem
Make sure your horn is straight in the rudder. don't mix a straight arm with an offset arm. I built the same plan, and had much better luck crossing the cables.
Do a search. lots of info about this already
Marh
