RCU Forums - View Single Post - BVM F-16 EDF Conversion
Old 09-27-2012 | 01:24 AM
samdimaio
My Feedback: (106)
Default RE: BVM F-16 EDF Conversion
BVM designs the internal cooling on their F16 to be accomplished with 2-mods. First is by removing the small pointed area on the fuse located just just above and to the rear of the main inlet opening - removing about 1/4" - 3/8" of this front "beak" point. And second is by adding a former in the tail cone that is designed to allow the cooling air to escape. I believe NACA type inlets will accomplish the same result as long as that tail cone former is installed for the air to exit. Also, there are several mods BVM recommends be done to strengthen the air frame and stabilators. These mods are not difficult and all the parts and instructions are all included in the conversion kit. When done you will see that these mods do improve the jet's structrual integrity. IMO, the BVM F16 is a very special and rare plane - the conversion kit is worth considering.
A few months ago I completed converting our BVM F-16 from ICDF to EVF 12s power using the BVM conversion kit. Many have seen my 2 sons fly this plane on electric power and it does leave an impression.
You will find that the performance increase with the EVF-12s conversion vs. ICDF is significant - much shorter takeoff roll, greatly improved vertical, 170-180mph top-end and best of all, NO FLAMEOUT WORRIES at low air speed. We set timer at 4:30 for the gear pass and it seems to work well. The Thunderpower 4s, 65c, 6600mah packs are only slightly warm at the end of the flight with about 75% of the capacity consumed.
It sounds pretty good, too - particulary high speed, power off fly-bys. You will be pleased.
call me if you need help; sam dimaio 610-436-5552
