RCU Forums - View Single Post - Throttle cut function
Old 09-27-2012 | 06:04 AM
Bax
Default RE: Throttle cut function
The normal operation of the throttle function is to have the engine at idle when the throttle stick is down. The throttle cut will lower the throttle from there. If your engine is at full throttle when you have the throttle stick down, then you are operating your system in a very non-standard manner, and the throttle cut won't work for you.
