still has the opening for the throttle cable mold in and still has the huge giant opening for the nose wheel that is not needed and don't know why it needs to be so big. it should just be a 2 inch wide opening not a drumstick looking thing. and the reason it's like that is because they did not want to redo the mold for the nose wheel liner
ORIGINAL: TimWatson
ORIGINAL: ModellbauUK
I must resist!!! I must resist!!!!!
That old Troll must not be fed!!
Eventually it will die of starvation!!!!
Or the reason these same things keep being said over and over is simply because they are true.
Does the V3 still have the moulding in the back of the fus where the throttle cable was supposed to poke through when it was a falcon 120
