ORIGINAL: TUMBLER
I know the hole isthere for retracting the wheel I've been been building planest for 25 years lol. my point was that they made the holde way too big. the hole should have been made a lot smaller and then allowed to be opened up by the modeler. just like a composite are spark nosewheel is done. . I have 1 inch gap on each side of the strt which is not necessary. I'm not going to argue with you about it but the opening is way too big and it's because they did not take the time to make a new new nose well liner honestly there is no need for a nose well liner and I do not even have 1 in mine so it would have been nice if they would have made the hole smaller because now I have a giant opening that is not necessary and just cosmetically looks bad
ORIGINAL: ModellbauUK
Tumbler
That hole is perfect for strapping turbine cables and fuel line too. You could say it was designed for it.
The hole at the front is where the nose wheel goes when it is retracted. If it was not there the wheel would bag against the fuse and wouldn't fully retract
