RE: Goldberg Tiger Club
[/quote]
Since you have the engine, why not! One thing I would suggest is to use an aileron servo in each wing. My Tiger with the original long aileron torque tubes would flutter on down lines so I had to go with the dual aileron set up. I would expect with that 55AX hauling it around, it would be even more prone to flutter.
By the way the 55AX uses the same mounting holes as the 46AX so if you ever need to change engines for any reason it is an easy swap.
[/quote]
Yes, thanks for reminding me about the dual servos, that was on my list of mods. Somewhere I have a list of mods I need to find, but I think the dual aileron servos was the main one.
