ORIGINAL: bikerbc
Do328 jet #50 do you know what your all up weight is? That a pretty big motor for sure... You will be able to use it on your Tiger 60 if you ever build one...That would be too tame , You will be needing the Saito 1.80 at least by the sounds of it..
no he was quoting me. my Tiger 60 has a SAito 150S the old high lift cam model. it rocks with a 16X8
I have two Tiger twos one with a .61 FX and one with a Saito 125. the one with an os .61fx weights 8.5 pounds
edited for grammer and content.
