RCU Forums - View Single Post - Correcting loose hinge
Old 09-28-2012 | 03:49 PM
PDF
Default RE: Correcting loose hinge
Hi Ahicks mentioned in his reply unless it a real mess. So I went down stairs and put in the hinge with two pieces of note book paper, one on each side of the hinge just to see how much space there was. With a piece on each side it's snug enough not to fall out and you feel a bit of resistance, in other words if it was like that in the beginning I would be content. Hopefully this gives you a better explanation. With this said would you think I'd have any problem just glueing it in. Thanks again.
Pat
