RE: Chargers
Deans?Yep. I've standardized on theStandard except for the Dean'smicro (my little EDFSabre). But then there's the 3/4 inch wide seven pin balancing jack on the Triton that is incompatable with the 7/8" wide eight pin jack for the 3S balancing adapter for the EONbatteries, which have four pin balancing jacks . . . but not the Electrifly four pin size and is the slightly larger FlightPower/Thunder Power four pinjack instead. So if Ihave the Equalizer to go between the Triton and the EON I'm OK. Though my transmitters use a Futaba 1/4" jack, though the Rx batteries use the Futaba J . . .
Ahhhhhhh!
I'm going back to free-flight elastic band powered models!
