RCU Forums - View Single Post - ESM, Ever Soaring Models Any Good?
Old 09-28-2012 | 11:16 PM
grassie's Avatar
grassie
Default RE: ESM, Ever Soaring Models Any Good?
Well, I guess one should first read and then buy.[] I for one did it the other way around [&amp;:]and when reading this thread went running for my kit to have a look.[:-]<div>I am glad to say that I am satisfied with my kit.[8D] Painting looks good, covering needs a touch here and there, but generally good. I don't think I will use the hardware that came with the kit, after all, I did not buy hardware, I bought an air frame. I believe a guy in Cape Town has built one and used a DLE 30 having to add only 2oz of lead in the nose. A 20cc should be enough for this plane but if you are going to add ballast, why not add power at the same time. It can't hurt. If I can figure out how this browser works I will add some pics to make your mouth water. Now don't all of you go running to buy one. It is nice to have the only Dauntless at the club.
</div>
ID:	1805924   Click image for larger version
ID:	1805925   Click image for larger version
ID:	1805926   Click image for larger version
ID:	1805927   Click image for larger version
ID:	1805928   Click image for larger version
ID:	1805929   Click image for larger version
ID:	1805930   Click image for larger version
ID:	1805932   Click image for larger version
