RCU Forums - View Single Post - TOP FLITE GIANT SCALE P51 ARC
Old 09-29-2012 | 06:09 PM
Leroy Gardner
Default RE: TOP FLITE GIANT SCALE P51 ARC
ORIGINAL: Thunderbolt47
Nice looking plane. however an 8 pitch prop will be far from 115 MPH. It will be lucky to hit 100. A 22x10 might get you near 100, a 20x12 will get you around 115 a 18x14 will get you too 125mph. This is of course if your engine can turn these props at around 7300rpms on the ground.
I saw a T/F today with a 22x8 fly. It was very ''scale like'' around 85 mph.
My mustang flys at a very ''unscale like'' speed of 135mph. G-62 with T-6 racing prop on RCexel ignition. turns 7600 on the ground.
Agian nice plane.
Here is mine. 26lbs also
I may be off on the prop size, That just came off the top of my head, matter a fact that is the break in prop for the DLE55. If I recal, the G-62 and the DLE55 power ratings are about the same, I'll check that out and say the Dle55 has pulled a number of these planes to 115MPH and my plane will create less drag than most of them. Leroy
