RE: CMP 120 Zero ARF Build thread
Back to the wing and some progress. Lighting is installed, tested and lenses/covers molded and formed. Left side now done and ready for joining and glassing. How did I ever get anything done without a vacforming set-up?[&:]
The lites are actually pretty bright and readily visible in the sunlight, camera doesn't pick it up so well though. All seven (7) lights can be lit with a single pair of AA batteries (3v); 5 xenon bulbs-2 in each wing top and 1 in the tail, plus 2 led bulb assy's (1 in each wing tip). Each of the lights are individually servicable without cutting or rewiring; basically PNP. They will be switchable by a micro-servo actuating a micro-switch.
