RE: Shrike 40 with thinner airfoil
I'm with MJD on this one. I think you'll be OK, but always do your run up with no one in the prop arc. After each flight, inspect the blade root/hub area for whitish marks and retire the prop if found. If you think the prop took a hit at landing, retire the prop.
