ORIGINAL: AndyAndrews
Here is a pick of the recommended system (I think). I say this because there is no information available from the factory other than pictures. As it stands with this open type system air bleeds by the cylinders. Currently the 8711 servo strains itself actuating this system as it's set up. I've tried enclosing the open ports on the servo cylinders and it gets even harder to move.
And...one question, not ¡s possible use one only piston for rudder ? using the two nipples, if you place the piston in the midle position you can control the rudder.
You can do this as well?
BR from Spain.
Carlos Márquez
_________________________________________
http://cmjets.blogspot.com.es/
