ORIGINAL: cumminspower5.9
Well for the first time since I have owned the XS, I pulled apart the transmission to inspect and clean it. The slipper pad has been completely torn to shreds but remained in the transmission in a powdery form lol. It was totally gone, but it still wad enough material left on the hub to grip lol. Crazy. Now the diagram in the manual seems to show 2 slipper pads. Mine only had one. Correct me if I am wrong.
remove the small pin and the other side with the other slipper pad should be there.
when i wascleaning my center transmission, both pads look very worn out. going to replace them before putting it back together.
question, I cleaned off all theoil sludge in the center transmission cause most of it were turning green.. Can i just used wd40 to replace that oil sludge?
