Ca hing
Just read the sticky about hinges and proper install. Says to push hinge into surface to the pin then put the corresponding part opposite then add drops of thin Ca.
1. The hinges won't move when placing the other surfacer on opposite side?
2. Just a few drops at the drilled hole or run a line across the hinge also?
Will be watching for some good comments here. I know if one hinge gets off a little a binding will be the result and this scares the heck out of me. lol
gphil
