RE: Ca hing
gphil, I dont do mine exactly as stated above. But there is not a binding issue. When you flex the surface for the first time after gluing. That line will the hinge line. No matter the oriantation of the actual hinge. CA hanges can bind but this would be a result of them not being in line along the length. If that makes sense. I have not read the sticky you are talking about. But the most omportant step is to flex the surface while holding the gap tight before glueing. CA hinges will last a long time if they are not being pulled.
david
