RE: COMP-ARF A-4 BUILD
I can get all the air out of the system and it will work perfect with one master and one slave, but somehow air creeps back in eventually.
here in lyes another problem: you have to submerge the whole system under fluid to remove air then find a way to instal back in jet with not dismanteling. the tubes are supposed to run down this protective shield to keep the lines from being pinched or cut. this is not possible now because you cannot disconnect lines.
scott
