RE: $1,000.00 bounty offered to fix COMP ARF A4 steering
Hi,
No experiance with a Carf A-4 however some how some way you will need to construct a bleed valve and possibly pressurized injection of the fluid (5-7psi) all while moving the cylinders. No way will submerging under oil get the air out...or at least not all of it. Get the correct size cylinders and ALL the air out and it should work. Good luck to you and I hope you get it resolved.
Take care
